i would say the avg. battery lifespan is about 1 -2 years. 2 years if you get lucky and this will also depend on how much you use it and how well you take care of it. laptop manufacturers usually will offer 2-3 year warranties on their laptops but the battery is often under warranty for only up through the first year. 🙁
