I made the mistake to run System Stability Test with Aida64 on my Toshiba Satellite A205 laptop when the laptop was disconnected from the power grid and now the battery is not functioning properly anymore. I have Windows 7 installed and when i hover the mouse over the battery icon in the system tray it shows a message "Consider replacing your battery". And even it shows that the battery if fully charged if i power off the laptop, disconnect it from the power grid and start it on battery power the battery discharges for about 5 minutes from 100% to 0%. Before that the battery lasted more than hour and a half.
Is there any was to fix the battery or the battery is gone?
