Ok, what I need to know is, is it possible to charge your laptops battery, and still be using power FROM THE BATTERY at the same time? If yes, does it depend on the laptop, or is it possible for all laptops?
Another question... If I have a battery in the laptop, but then I have the laptop connected to a AC outlet at the same time (currently running off the AC outlet's power), If I unplug it from the AC outlet, will it still run off of the battery's power? Or will it turn off?
I ask the first question because, I plan to have my battery charging at all times in my car, through the cigarette lighter, so if I turn the car off or on, start the engine and what not, the laptop would still run. The second question is because, if I cant do the first option, If I run the laptop off of the power of the cigarette lighter/AC converter, but then turn the car off, and the battery is in, will it still run or shut off?
If ANYONE can answer these 2 questions, I would appreciate it.
