- Jan 16, 2003
- 1,531
- 0
- 0
Toshiba Tecra 8200 (P3-1000, 256M RAM, 40G modern HD, wireless network running)
I just picked this up from a technically challenged owner. It has been treated gently but probably not with geeky care.
The battery reads 100% at the start, and runs the machine for around ten minutes before the 3% battery warning lights up. It's a litium ion battery (Toshiba Li-ION battery pack Model No. PA3062U-1BAR DC 10.8v 3600mAH).
I know that at least Ni-Cad batteries can be rejuvenated somewhat by fully discharging (to around .9v output per cell) then recharging it again. Is there a trick like this to make a lithium on battery feel young again?
Thank you.
(edited to remove technical omissions and to make you wonder)
Thank you.
