Laptop battery practices - Leaving it plugged in
FishTankX
2,738
If I leave a laptop just running off wall power for 5 hours a day, with a full battery, will that be bad for the battery?
Also, what's the best practice for a laptop that will be run half off wall power, half off battery?
ElFenix
102,393
8,552
modern batteries aren't supposed to have any problems with that.
JBT
12,094
I would take the battery out if it were going to be plugged in for 5 hours "just in case" it does hurt the battery. I have heard from people you should do this even with LIthium ions.
ponyo
19,688
2,811
I would take the battery out of the laptop if you're going to use it plugged in.
corkyg
Elite Member | Peripherals
27,370
239
That is exactly what most manufacturers recommend as well.
AWhackWhiteBoy
1,807
people are still hung up on old technology,most any reasonably new laptop uses a lith ion battery which doesn't suffer this effect.
