Laptop battery no longer charges
Brian M
OK so I have a ~4 month old Dell Inspiron 700m laptop. Last night I let the battery drain until it was dead. Now when I plug in the AC adapter the battery will not charge. No charging light, windows says no battery present, and when booting the BIOS gives an error that says no battery present.
I'm assuming I just let the battery drain down too far for the computer to even detect it any longer. I know this battery must be OK still, so can anyone think of a way I could charge this battery so the computer will start recognizing it again. My machine still works fine, but only running off the AC adapter. The battery is rated at 14.4v and has 7 contact pins, one seperate than the others and I don't know which would be to + and - to try hooking up an external power supply directly to the batteries contacts.
If anyone has any ideas I'd appreciate it!
PS: Dell Support is real good, called them and they said I'm screwed.
sharkeeper
10,886
Do NOT try to charge this pack by connecting any source of EMF to the contacts. The packs are proprietary and should be serviced by authorised personnel qualified in Li Poly - Ion secondary technology. Improper use, charging, etc. can result in serious personal injury due to fire and/or expulsion of hazardous alkali metals.
Cheers!
Brian M
Scratch that idea off on fixing the battery. haha thanks sharkeeper.
Anyone know of any software that will forcefully charge this battery?
Brian M
Maybe I should call up again and hope to get a better support agent. Damn India call centers.
Vegito
8,329
New Dell pc comes with 1 year warranty for the battery.. even if you bought the 3 year extended warranty, they only warrant the battery for 1 year.. if ur pc is only 4 month.. please call them and get a new one.. dont bother taking it apart, etc.
sharkeeper
10,886
What has most likely happened is one of the cells in the pack has fallen to below 3.0 volts. The circuitry in the pack will effectively shut off the pack and the computer ignores it. This can be corrected but as I said earlier it requires disassembly of the pack (authorised only!) and the use of a digital volt meter and regulated DC power supply.
If it's only 4 months old it should be under warranty.
Cheers!
Brian M
Called Dell back and convinced them to send a new battery, free under warranty!
Thanks for everyone's help/suggestions.
Brian M
u can't break a battery with its charger or draining it completely
Seems to me that's exactly what I did. Do you have any other possible explanations as to what could have happened?
buy a new battery
Don't need to, Dell is replacing this one for free.
cy7878
394
Sure you can. Try this at home: run your battery till it is at 3%, at which point you put the computer to sleep. Leave it asleep for 3 weeks, do not turn it off or recharge. I can assure you thye battery will DIE and no longer hold charge. Ask me how I know.
Carp1812
184
OK - I'll bite. How DO you know this? :)
cy7878
394
Accidentally, of course. Besides a big laugh from the IBM support guy, it was truely humiliating because I was at IBM's mercy to replace the $200 battery. Luckily, IBm stepped up and replaced it. The support guy told me to never ever discharge a Li-Ion completely.
sharkeeper
10,886
IF a battery pack is designed properly, it cannot ever be damaged by an end user unless abused. Abused = dropping from great heights, leaving in car in searing sun or extreme cold.
Running it down to MT will NOT damage a pack. If the protection circuitry present on the pack is not well designed or malfunctioning a cell may be overdischarged and not come back. They can be re-equalised but this is beyond the scope of the end user.
FYI, storing them fully charged will shorten their overall lifespan faster than storing them partially or fully discharged! It's not a huge factor, but it definitely exists.
Cheers!
