Laptop battery gauge?
armstrda
426
I got a new laptop at work, and it's no longer a Thinkpad. One thing I always liked about the thinkpads was the battery gauge that they had installed that was on the taskbar down next to the tray of icons. Does anyone know a free tool that does this same type of thing? I just want to know percentage of charge, time left, time til full charge, etc.
Thanks!
corkyg
Elite Member | Peripherals
27,370
240
Try using the laptop's Power Meter in the Nitification Area (formerly the "tray.")
PWR
BTW - are you using the laptop at work connected to A/C? If so, remove the battery.
armstrda
426
PWR
The only problem with that thing is that it doesn't have a constant reminder of the battery status (percent or time remaining on charge). And the icon only has 3 states (full, half, and you better shut down now!)
