Laptop battery died
runzwithsizorz
3,497
14
Asus ROG G73JH. The internal battery died. Currently running on power supply unit alone, which works fine.
I have 0% available, plugged in, not charging. Looking to replace battery or is it safe to run off power supply alone. How difficult is it to replace internal battery with a new one? Please advise.
The Wife
runzwithsizorz
3,497
14
Yes and no. the external battery/brick/power supply charges the laptop and internal battery. It's the internal battery that died. In other words, without the external PSU, the computer has no other power source (battery) and will not boot/run.
sdifox
101,236
18,234
... Flip over the laptop, battery is centre rear, disnengage latch on the left hand side and slide battery out. No dissassembly required.
https://www.youtube.com/watch?v=2WJqpLoncCw
Around one min mark he shows how to remove battery.
runzwithsizorz
3,497
14
Yes, but no more popping sounds...I can't say the demise of the internal battery was caused by the new PSU. Also. I've had this laptop for 5 years.
Wellcky
1,499
It is safe to just run it off the power brick/adapter. I use an old Gateway laptop been running for months now, with no issues.
