Lapping, what is it exactly, how do I do it, etc...
markrb
357
I have been reading that people are lapping their heatsinks. I am pretty sure that is sanding the metal down to create a better contact with the CPU.
How do I know if I need it? I have an OCZ Gladiator copper heatsink. If I need it how is it done?
What do I have to be careful about?
Thanks,
Mark
ST4RCUTTER
2,841
You've got it right. Just lap (sand it) until you can see yourself in the bottom of the HS! ;)
Seriously though, it's easy and only requires a little time and sandpaper. Get fine grit, like 800-1000. The only thing you have to watch out for is creating an uneven bottom that will prevent good contact with the CPU die. Welcome to Anandtech!
XXWoodmanXX
230
HERE is the finish I was able to acheive with a little patience and time. This is the surface of my Alpha PAL 8045 HS. :D
Good luck!
Emos
1,989
<< Here is an article:
SK-6 lapping
Wow...that seems to be a lot of work! I'm actually considering it though...just got my SK6 in the mail and have a friend coming over Thursday to install a few mods.
