LANPARTY UT nF4 Ultra-D ..HELP!!!
WA261
4,631
Just installed mobo. Upon boot the fans all turn on fine...then it is like the power kicks down and all of my fans slow...I go into windows then shutdown. Any clues?
nealh
7,078
When I first hit the power button..all fans are at max..then the fans become quieter as the bios slows the fans down
I have a DFI SLI-DR
this is normal..
you could go into the bios and set the speeds to full at lower temps
oh does winxp not load???? does it just reboot
did you do an clean OS reinstall
Munky
9,372
Yeah, the bios contols the fans based on temps at default settings, which I find a useful feature. If you dont like it, you can change it in the bios.
