While setting up my new rig, I was having some concerns about system stability in Prime95 and was tweaking FSB speed and CPU/RAM voltages.
Rather than trying to crank the voltages up to make it worked OCed, I was about to back the speed off and test a default and milder overclocks. After a couple of tweaks, I dialed the FSB back to 190 and the voltage to default, I hit F10 to save and restart and it DIED!!! I wasn't looking at it while it restarted, but I realized that the monitor hadn't kicked on - which occasionally would happen in the past (with other PCs) - though the hard drives were spinning. I hit the reset and still nothing.
Looking inside, the POST diagnostic LEDs flash the 1st and 3rd, then the 2nd stays on and that's all she wrote. A couple of times, it beeped every secord or two, but the crappy printed manual doesn't have anything in the way of trouble shooting info other than "make sure the monitor is on". (Thanks, DFI. ) At work now, I've looked thru the PDF on the CD and it's not offering much in the way of guidance. The light sequence has definitely changed from what it did before.
In the front of my manual was an addendum sheet on goldenrod paper explicitly warning not to power off or unplug the PC while rebooting after adjusting the CPU speed and I didn't - I just did the usual "tweak, hit F10 to save and reboot, live life" routine.
I've reseated the RAM (though the LEDs on the sticks are on) and cleared the CMOS jumper (the only place less convenient for this thing would've been on the underside of the mobo - absolutely retarded placement) a couple of times, but I'm still stuck. The keyboard doesn't light up either and I've tried two other KBs with no success, so any requests to press Alt+F2, etc., won't work at the moment.
I really need to get this puppy up and running ASAFP and any help would be greatly appreciated. Thanks in advance.
__________________
System specs:
DFI LANParty NFII - 7/18/03 BIOS ? Athlon XP 2500+ Barton @ 2200 MHz (200x11) default voltage ? Thermalright SLK-800A ? 1 GB (2x512) Geil Golden Dragon PC3200 ? Chaintech A-FX98 GeForce FX 5900 128 MB (450/900) ? Maxtor 160 GB/Western Digital 200 GB/Maxtor 60 GB/Maxtor 40 GB (all 7200 RPM) ? Lite-On 52/24/52 CD-RW ? Lite-On 16X DVD ? Antec Sonata w/380 W TruePower ? Generic WinModem ? Windows XP Professional SP1 (Corp.)
__________________
System specs:
