Just a guess, but I've got an EAH5850 in mine and it looks like a 6950 would be able to extend easily into an empty 5.25" bay if needed. I lean towards yes.
5850 here and it fits with ~2 inches to spare. The way my x58 board sits, even longer cards would still fit a bit more than that because the card sits high enough to stick into the 5.25 bays.
Here's my rig in the case gallery so you can have a look-see.
The K62 has 290mm of space, not counting the drive bays, which is 11.5". Since it has top-mounted PCIe connectors instead of end-mounted, there shouldn't be a space issue with a 10.5" 6950 reference card.
