Im having 2 problems with my Motherboard. The 1st one is getting the on-board Lan connectors to work fully. I was having problems getting access to my home network thru the on-board LAN connectors, so I put a PCI Lan card from Kingston in it. It worked on the network for a few days and then it wouldn't allow communication on the network anymore. Im able to get the internet thru the network from the host computer. Me and my brother did ping tests on our various computers. We could ping the other computers on the network thru my computer. But when we tried to ping my computer from the other two PCs, which are functioning normally, it wouldn't receive or recognize it. We also used the packaged software for the 3com lan connector to do a hardware loopback test of the port and it multiple times reported that the port failed to recieve. We are thinking that the On-Board Lan connectors are bad and that I need to RMA the board. What would you suggest or think I should try?
The 2nd question I have is :
I have 2 sticks of Kingston 256MB 2700PC DDR 2.5-3-3-7-2T on this motherboard. The automatic detection of the frequency of this memory thru the POST is 166MHz. Is this what is suppose to be? If not how do I modify it to run at the full frequency?
For Misc. Info I am using a 2100+ XP.
Thanks for any help you might have!
