- Mar 21, 2011
- 10
- 0
- 0
My brother is moving out. Im getting his room. I'm converting my original room into an office. I'd like to keep my gaming rig in my new room's closet as i leave my PC on 24/7. My rig isnt super noisy, but if i can eliminate the noise entirely, then i'd love to.
I'd like to have just my monitor with something like a Brazos nettop. I would like to stream (or virtualize) my gaming rig's desktop into the nettop as running cables from my office to my new room's closet would be very difficult.
Wireless DVI/HDMI solutions are very expensive and have range issues beyond 5 - 8 feet. The machine will likely be a bit over 15 feet. I'd like to have all the advantages of my gaming rig's power but the convenience of a nice little, quiet nettop. Ideally, i would want sub 200ms lag. Both machines will be on a LAN. I'd like it to be on Wifi, but i can switch to gigabit ethernet, if need be.
My monitor is a 1920 x 1200, so it needs to support that resolution at 60 fps. I would like lossless compression. Gigabit ethernet *should* be able to handle that throughput.
Any possible solutions?
