While going thru the BIOS, I came upon the option to enable LAN cable status and POST check LAN cable to which I did (although now, I wish I knew what they do exactly.)
Anyhow, prior to enabling this option I just finished a new install of winXP on my new system and everything worked great.
After enabling both of these options, my PC won't even get past the POST so I can disable this option in the BIOS. Sometimes the screen hangs after showing the HDD, USB status and other times all I get is a black screen.
Any ideas on how to fix this?
My unit:
A8N32-SLI mobo
2.5 gigs of ram
WinXP on Raptors in Raid 0 using RocketRaid 2310 PCI-E controller
3x 400Gb Barracudas setup in Raid 5
2x 7900GTO in sli
My unit:
A8N32-SLI mobo
2.5 gigs of ram
2x 7900GTO in sli
