This is my first watercooling build but i thought i had everything in mind.
Setup:
pump -> cpu - > gpu - XSPX 360 -> pump
I thought i wouldnt need a res, and mounting in in my stacker 832 would be too much hassle because i have so many HDDs.
The pump makes a constant LOUD ratting sound every time i turn it on when mounted.
Is teh pump supposed to rattle if there are only very tiny air bubbles attached to the tubing?
I tried it in a dummy loop to be sure if the pump wasnt defective, and after some turning and when all the air was out of the loop the pump turned silent. I was holding it on my hand.
The weird thing is, the pump is only silent when the left side is facing down. When leveled, ratting begins again. I have reseated the aquacomputer top several times now, and no improvent. I even ran it leaky to see it the screws were too tight.
Should i just leave it rattle away until the system has finished bleeding? No res here.
Setup:
