I manage a lab that has a handfull of computers, each on two networks: a local network AND a large network that I do not have admin access to.
We use the large network for most purposes including WAN access.
We use the local network for testing.
It's important to keep these networks isolated from each other (I dont want machines just on the local network to have internet access, for example).
The stations have two NICs, and they have no problem pinging both google and local IPs.
As part of what we do in the lab, we often use the config interfaces of some network switches. Using telnet to access the switches isn't a problem, and works great. The problem is that these stations cannot access the switch's WebUI. It appears that the stations attempt to find the destination IPs on the WAN instead of locally, and end up timing out.
What settings can I change on the stations such that when accessing a specific network (the local network) to first look on the second NIC?
If this is in any way unclear please ask!
Thanks in advance!
Thanks in advance!
