network project at school: using active directory, setup 3 sites (on diff subnets, obviously) with blah blah services
to use:
one classroom thats in use by other classes. the room has 18 machines with vmware and Im to use the machines as hosts for my AD servers and workstations.
access to the cisco lab equipment we have racked up: some old routers and switches
also in the classroom: catalyst 2950 that all of the machines are connected to for accessing the campus network
i work with the network admin, he said he could just create me 3 vlans and write a script or let me change the switch config when im in the room. the instructor is "not comfortable" with this, and also wants to be sure that I can use a router.
so the admin lends me an 1841 router and suggests the following:
on the room's 2950:
on the 1841:
conclusion:
this doesnt work. he was gone by the time i set it up. Im not sure how it *could* work, to be honest. is he completely amiss on this one or have I setup/understood something wrong?
to use:
on the room's 2950:
- set fa0/21 on the 2950 as a trunk port
- use fa0/9 on the 2950 as an access port on that rooms VLAN (each room in this building has its own VLAN)
on the 1841:
- fa 0/0 with 4 subinterfaces
- 3 for my VLANs
- (used only by me. im given 172.20.0.0/16 to use as i like, and nothing else on campus ANYWHERE has an address in that range)
- 1 for a vlan to give me segregated internet access
- (gateway 192.168.251.2 going out to a DSL line separate from the rest of the campus internet connection, and nothing else is in that address range)
- 3 for my VLANs
- fa0/1 with an ip local to that rooms VLAN (192.168.125.2 /24)
- VMs on hosts can ping one another, as theyre all on the same vlan. makes sense.
- physical hosts in that room can ping 2 of the 4 subinterfaces on 1841: fa0/0
- VMs cannot ping the 1841 at all
- the 1841 cannot ping the VMs at all
conclusion:
