L4D itch got me, Need help choosing card!
picachux
247
Would love to grab a card that will allow me to play alot of the current PC Games but it's mostly for L4D. My PC is listed below in my sig, I would like to keep it to $80 @ Newegg if possible.
AVP
885
I would go for a 9600gt
The MSI and Zotac ones have good ratings and are in your budget after MiR
cusideabelincoln
3,275
46
The 9600GT or the HD4670 will work fine. The HD4670 will probably be a little cheaper and the 9600GT will perform a little better.
Spike
6,770
If L4D is your primary concern the 4670 will work great for that and save you some cash. If you do want to do some more gaming then the 9600GT is a little faster for not much more money though it does consume more power (may or may not be a concern for you).
Too bad those $34 9600 GSO deals are all gone, those where the best!
I4AT
2,631
Originally posted by: theAnimal
8800GS for $36.
Anybody know if status-now.com is ok? It's located in Tempe, AZ where CPG did all their processing, and Slickdeals has warned against sending rebates that way.
picachux
247
XFX 9600GSO 768mb 192-bit | ATi HD 4670 512mb 128-bit same price $75 or ATi HD 3850 512mb 256-bit $85
edplayer
2,186
The 9600GT has been on sale for around $60 after rebate a lot recently. I suggest waiting for one of those deals.
VirtualLarry
56,581
10,220
I don't know what's with 9600GT prices, but looking at NewEgg the other day - there are plenty of 9600GTs that are more expensive than 9800GTs. Go figure.
