Looking for reliable, inexpensive (under $60) 2-Port KVM Switch for PS2.
Want:
1. Switch via switchbox button as well as keyboard hotkey.
2. Accommodate Linux, Win 9x, Win 2000, Win XP
3. Reliable re:
a. I've read that some KVM switches use the keyboard (only) for switching
and that they may not accommodate Linux.
b. I've read that come KVM switches require a special adapter to run with
Linux.
c. I've read that some KVM switches are susceptible to the order that the
2 PC's boot, or which PC (if any) is turned on.
d. I plan on running 1024x768. I've heard that higher resolutions
require higher quality (shielded) KVM video cables. I'd prefer a unit
whose default video cabling is shielded (et al).
e. 1 to 2 second keyboard/mouse freeze between switches is okay, but
significantly longer is not.
Unsure whether to get KVM Switch that includes audio. I plan to normally not
have the audio connected to the KVM switch. This way I can listen to a CD on
1 PC, and still get the sounds from the other PC. However, I may
occassionally wish to connect audio on both PC's to the KVM Switch.
Therefore, since the extra cost is only moderate, I'd prefer that the KVM
Switch optionally allows the user to includes audio in the switching.
I'm considering:
BELKIN 2-Port KVM Switch with Audio Support and Built-In Cabling,
PS2, Model F1DL102P
BELKIN 2-Port KVM Switch (no Audio), PS2, Model F1DB102P
StarTech 2 Port StarView KVM Switch with Audio, StarTech.com ID: SV211KA
The StarTech model is more expensive, but if feedback says that is much more
reliable than Belkin, then this is what I'll go with.
Request feedback, references to website reviews et al, and recommendations on
other (alternative) KVM Switches.
Want:
3. Reliable re:
Linux.
I'm considering:
PS2, Model F1DL102P
