so.. i got the KT7A-raid mobo... revision 1.1...
works stable at 150MHz fsb @ cas2 (M.tech AMD OK pc133)... the first 30mins in windows... then it starts to lag every ~10secs.. it stops for like some ms... and it's very annoying. .. and i don't know if it's the board that can't handle the 150mhz fsb at cas2 or the memory that won't work that way....
but i have my doubts about the mobo.. cos i can't reach over 150MHz fsb even with cas3...
but in the other hand... why should it start being "unstable" like that after like 30mins as i said... so it sounds kinda weird...
so anyone know if i can change any settings in bios or something to reach higher FSB or run it smooth at that speed... (and i run the processor @ default speed when i FSB clock)...
other specs are
Gainward Geforce 2pro
sb live platinum 5.1
thunderbird 1400MHz
real magic hollywood plus dvdcard
netgear 10/100mbit FA310TX
Creative DVD-rom 32x5x
Hewlet Packard 8x4x32x
2xSeagate barracuda IV
60GB 60GXP
i appreciate any help...
yo!
other specs are
thunderbird 1400MHz
60GB 60GXP
yo!
