kt7 raid question about heatsink connection
Balael
201
will the kt7 raid be able to handle the fop38 for a motherboard power connection? or am i gonna have to get a 3 to four pin adapter to hook it up to the main power supply? thanks a bunch.
pj
Techwhore
1,248
I run mine off a 3 to 4, but others have said that it works fine off the board... I would think the board could handle it (it does have 4 fan connectors). You may not want to use all 4 though, but if it's just the delta or that with another fan you should be good.
DaddyG
Banned
Mar 24, 2000
2,335
Balael,
Maybe I'm paranoid but I never run any fans off the mobo headers. The headers will often produce less than 12v. Don't want to replace mobos cause of burn out headers. The fan rpm monitor can still be connected to the mobo header with a little work.
