KT7-RAID Problems - HELP!! :-)
Redsho
30
:disgust:
I've been trying for days to get my machine working the way it should be. Tried doing just about everything, but still things are not working out!!
Here's my system:
ABIT KT7-Raid w/ 1100mhz thunderbird
2 x 256mg Micron PC133
ATI Radeon 64DDR VIVO (AGP)
Adaptac 2940UW SCSI Controller (PCI 3)
3Com NIC (PCI 6)
Sound Blaster Live! (PCI 4)
Seagate Hawk 4.5GB Int Ultra Wide SCSI HDD(Id=1)
Plextor Ultra Wide 40X Int CD-Rom(Id=2)
Yamaha 16/10/40 Int Scsi CD-RW (Id=3 & terminated)
Zip 100 Ext SCSI (Id=5 & terminated)
2 x 45gb WD 5400rpm HDD (Master drives on IDE 3 & 4)
OS = Windows 2000 Pro
Latest Drivers for all devices installed....
I've been trying forever to get this working... took me almost forever to get everything to work together for some reason... Had to relocate half of the pci cards in order to setup up Win 2000.
After had everything finally working (I thought...). I tried downloading a divx avi file roughly 500mb on my raid drive. After download completed, I clicked on file and my computer just locked. I thought it was a fluke, so I resetted the machine. Tried clicking on it and it still did the same thing. I then thought it might be the file, so I downloaded another divx file, about 460 mg. Once downloaded, clicked on file and it locked up machine again. Restarted machine again thinking that it might possibly be Windows Media Player 7... so without clicking on the file itself, I ran various programs (Global Divx, BS Player, and ATI File Player)and tried to open the file----Still locked up the computer. So again... restarted machine and de-installed Media Player 7.
Now, I took a small video clip off my cd-rom about 45mg, copied it to the raid drive. Once completed I clicked on the file, assuming that the same thing would happen again.... but didn't lock up... however I tried playing it and it locked up again!!!! Seems like the raid drive has problems reading large files????
*.mp3 files plays fine on the drive, but they are all less than 5 megs. Any Suggestions...?? Please help.... So many problems with this computer setup.... Sorry to ramble on for so long, but hopefully someone will try to help me out here, or I'm going to have to re-install everything for about the 6th or 7th time.
Thanks,
Doua
Redsho
30
Damn... can't believe it's this late already... but still no responses... and still trying to fix this damn problem :-(
Can anyone assist???
sad
437
Have you consulted the Unofficial KT7 faq?
Here's a suggestion that helped me a lot with lockups. Go into Bios>advanced Chipset> disable 4Xagp and change your driving control to 68.
