KT7 ad 266FSB CPU does it work?
Hippotoddimus
The KT7 motherboard does not officially accept 266FSB CPU's, I want to put a 1.4GHz 200FSB CPU in this motherboard however they are impossible to find. Can I put a 266FSB CPU in and have it work? This is a reply to this question from another forum. Is this correct?
Your CPU has a multiplier.
Your motherboard has a default FSB speed.
The speed of your processor = default FSB * cpu multiplier.
The only difference between a t-bird 1.4/200 and a 1.4/266 is the multiplier. When you pop the chip into your comp, your mobo will run at its default FSB (100 double pumped in your case). This will result in your cpu (1.4/266) being slower than it should be because the multiplier is too low. With the chip unlocked, all you have to do is go into the BIOS and change the multiplier to 14x and you are good to go.
What the other Forum gave you was correct. Make sure you flash to the latest BIOS revision to enable the 14X multiplier. I'm afraid that the highest multiplier you can find would be the 12.5 🙁
14x multiplier is only available of the 1.4GHz Athlon with 200MHz FSB.
Look here for more info
Running a 266FSB 1.4Ghz Athlon on your mbrd would result in a clock rate of 1050MHz ,if you unlocked it you could set 12.5x to give you 1250MHz.
