~~KT4V~~ Front Panel Pin Connectors (USB + Audio)
Dominic
186
Hello All
I have a few questions on setting up the front panel pin connectors from my case to my new KT4V board.
First question: USB
My case is usb 2.0 (Raidmax Scorpio)it has two seperate pin connectors a 4 pin and a 4 pin + GND pin on the second wire. I assume I put the GND in the JUSB1 #10 slot which is marked (USBOC) in my manual. Is this correct?
Second Question: Front Audio (Microphone, Headphones)
The front panel Audio Connector: JAUD1
The four pin connectors that my case has labeled is:
1. MIC DATA
2. MIC GND
3. EAR R
4. EAR L
I am pretty sure MIC DATA goes in pin #1, and MIC GND goes in pin #2. As far as both EAR pins, I am not sure and would appreciate some help in this.
Thanks in advance.
Dominic
PrincessGuard
1,435
1) USBOC (USB OverCurrent protection) should not be connected to ground. Since pins 7 and 8 are already grounded, you can probably leave that extra GND wire hanging there.
2) AUD_FPOUT_R, AUD_FPOUT_L connect to EAR R and EAR L. However, since it doesn't look like your case has audio return wires, you won't be able to use the back panel audio jacks.
