KT266a and USB problem
jonny13
440
4
I have built two athlon systems in the last two months and both have problems shutting down with a USB mouse plugged in. I don't know if it is just with a mouse or anything plugged into the USB. When I go to shutdown it powers down and immediately powers back on. The same thing happened with two different boards from different manufactures. One was a ECS and the other was a DFI. It didn't happen to start with, so I am thinking it is something with the Via 4 and 1 drivers or something. I don't have the computer here, so I don't know what version I installed, but will find out tomorrow. Any ideas?
Jonny
GrayWolf2000
10
What type of mouse is it? I had a similar problem with my logitech usb mouse until I updated the drivers. It was an IRQ resource conflict.
jonny13
440
4
One was an Intellimouse Optical and the other was a Wheelmouse Optical. I installed the latest MS drivers on both, so that shouldn't be it. I can take a look at the IRQ's and see if there is a conflict. What is the easiest way to go about doing that, just going through each one and looking at the number or is there some other way.
Jonny
DaiShan
9,617
update your via 4 in 1's, there have been instances of usb problems with older 4 in 1's.
mee987
773
In device manager, go to View->"Resources by type" if you wanna see all your IRQ uses at once
jonny13
440
4
Cool, I will take a look at that tomorrow when I get up there. So, if no IRQ's are set to the same, then there shouldn't be an IRQ conflict, right? What could it be if it isn't an IRQ issue? It is just funny that I have had it happen on two board now and they are the only Via boards I have ever used. All the other computers I have built had Intel and I haven't had a problem, so I just figured it was a Via driver thing. Anyways, thanks for the help and I will check that out.
Jonny
mee987
773
note: you will have a bunch of devices using irq 11, windows (2k/xp) uses irq 11 to create 255 "virtual IRQ's" so that you wont run out of em.... I read that somewhere
so dont be alarmed when you have like 5 devices all on irq 11, they arent conflicting
