KT133a USB port problems
Reverber
75
I have a FIC AZllea and the USB ports on it or Via tech.I was told the USB ports on my mobo have a common error(which is why i cant use my DSL on it b/c the DSL adn everything connectoed to my ports shutdown.)Has anyone heard of this or know where i can get a patch to fix it?
Modus
Well first, what "common error" are you talking about, and what has it prevented you from doing? If it's working fine now, leave it alone.
But technically, you should install the VIA USB Filter for best USB compatibility. And if you're using Windows 98SE, you should download the Microsoft Win98SE USB Patch.
Modus
NFS4
47
<< Tigerbait, are you trying to make me look silly? ;)
Modus
Looks like you did that on your own:p
McCarthy
Just from personal experience (kk266-r) I've found the USB to actually work fine....
EXCEPT
With HP's crap drivers for the 930C in W98. Thought it must be the USB on my motherboard, after all it's VIA, but the mouse, gamepad, webcam, scanner all work fine, but try to print and it's reboot time. BTW, in W2K even the HP is happy.
It sounds like when you try to connect your DSL to USB (via a USB NIC I'm assuming) the USB dies. Same problem I had with my Soyo SYBA, a BX based board. It just couldn't handle any USB devices with much data flow. Like the webcam or the NIC I tried using. Seems in this way it varies board to board more than by chipset from what others said when I asked about my problems way back.
Not much help, just one of those &quot;maybe if I share this, it'll spark an idea&quot; posts.
--Mc
