ErikaeanLogic
Hi🙂
I need some technical advice from you, my brethren, on the following scenario:
I installed and ran an ASUS A7V133 with a T-Bird1000@1301(1.85V) on my system and it ran totally stable. I benched it for 12 hours of continuous Sandra "Burn-in Wizard" followed by 24 hours of continuous UT "Timedemo 1" with no crashes or hangs. The UT bench was run at 1600x1200 resolution with 32-bit color depth, smooooooth as glass(63fps). This is the rig I ran it on:
A7V133
T-Bird1000@1301
Maxtor 20GB 7200rpm ATA/66
Radeon 64MB ViVo
Aureal Sq2500
3Com 905b
Pioneer 115 DVD drive
NEC floppy
Antec PP303X 300W power-supply
I just transplanted the A7V133 and the T-Bird to a friend's system and it hangs, crashes, or both, even when running at 700MHz. What gives? Here's his setup:
A7V133
T-Bird1000@1301
IBM Deskstar 20GB 7200rpm ATA/66(master boot drive)
Western Digital 15GB 7200rpm ATA/66(slave)
Quanum Fireball 8.4(?)GB ATA/33(slave)
Radeon 64MB ViVo
Aureal SQ2500
3Com 905b
Pioneer115 DVD drive
Plextor 12x10x32 Plex-Writer
Mitsumi floppy
Antec PP253X(250W) power supply
There are a few differences in our respective setups which I suspect of causing the instability:
1) He has 3 harddrives and is using both the VIA and the onboard Promise controllers to run them.
2) His harddrives are running at mismatched ATA ratings(no RAID, though).
3) His power supply is a 250W and mine is the beefier 300W.
The power supply issue is my leading suspect, and I will be swapping them out later. Any other theories? I'd really like to hear them.😉
Thanks for your time!🙂
A7V133
T-Bird1000@1301
Radeon 64MB ViVo
Aureal Sq2500
3Com 905b
NEC floppy
A7V133
T-Bird1000@1301
Radeon 64MB ViVo
Aureal SQ2500
3Com 905b
Mitsumi floppy
