- Jan 20, 2000
- 872
- 0
- 0
Motherboard is a Chaintech 7AJA2 which is SDRAM-based and uses the Via KT133A chipset. Current CPU is a Athlon 1000C(1000mhz/256k/266fsb/7.5x/1.75v).
Can I use a Thoroughbred-B Sempron 2500+ (1750mhz/256k/333fsb/10.5x/1.6v)? I realize that the kt133a does not support the faster bus speeds, but can the processor be run underclocked at 266fsb without any issues? Since all the pieces are basically discards, it does not matter if the machine is not running optimally. I just want to make sure that nothing fries.
Thanks.
Thanks.
