KOTOR 2 PC question/help
HonkeyDonk
4,020
So I'm at the part where Atris takes you captive and then when you get released, you can spar with the handmaidens.
I'm at the part where you fight all 5 and I'm finding it impossible to do.
Is there any trick to beating it and if you do beat it, do you get anything special? I'd rather not waste my time if you don't get any rewards at the end.
tia.
Bateluer
27,730
8
Would help to know more about your character, class, level, equipment, etc.
Never did that quest myself, so I'm not sure what type of reward you get.
HonkeyDonk
4,020
Well, since you never did that quest, I guess it would pointless to tell you what my stats are?
