koolance liquid cooling
tony4704
336
Im looking into doing a custom setup using the koolance INX-720SL Cooling System. I have a few questions though as this is my first liquid setup ever.
btw I am going with an AMD overclocking setup. I havent narrowed down what I am buying yet because im planning cooling first but Im going as close to top of the line setup as possible.
1) Anyone know how loud this unit is? I am going liquid cooling for 3 reasons, performance for over clocking, noise and asthetics. I would like it if this unit was pretty quite.
2) is the 3/8" ID good enough for cooling all this? (I want to cool ram, cpu, 2 hard drives and motherboard chipset, basically anything that radiates heat)
3) to cool all these things should i throw a second blackice radiator into the front 120mm fan slot for a dual radiator rig?
Im looking at using swifttech for the water blocks, atleast the cpu one and probably a Swiftech MCP655 Inline Pump. If anyone has any recommendations on what I should use instead for any of the parts let me know.
Also in order to handle all of this what size noiseless power supply should I use? thank you.
