Klipsch cable help
Rinaun
1,196
Hey all,
I had some issues with my Klipsch Promedia 2.1 set so I boxed it up for a bit. After 3 months, I finally went to try to fix it, and found out I'm missing one of these:
http://www.klipsch.com/product...-speaker-wire-set.aspx
I know this is a common cable, so if anyone knows where I can order one of these, it would be hot!
Also, if one of the speakers is broken as I fear, can I use any other home audio speakers for my 2.1 setup? If so, please guide me to the right ones.
Thanks,
Rinaun
Speakers: http://www.klipsch.com/product...ails/promedia-2-1.aspx
PurdueRy
13,837
4
Originally posted by: Rinaun
Hey all,
Thanks,
Rinaun
Just make it. Pick up a mono 3.5mm cable and some small gauge speaker wire(20ish) solder and your done.
iRONic
7,994
3,316
If you can't get it locally PM your address to me. I'll send you one for the cost of shipping.
Rinaun
1,196
Hey all,
Thanks,
Rinaun
I would actually do this but my soldering iron I currently use is basically dead (20 years old). YGPM ironic, thanks!
Rinaun
1,196
Originally posted by: MrChad
You can make your own cheaply, and they will work much better than the stock wire that ships with the speakers.
read thread please thx.
iRONic
7,994
3,316
Originally posted by: iRONic
Check this guy out;
http://www.elliot-tronics.com/
He doesn't seem to have anything on ebay and that seems a bit overboard. If I can't get one of the speakers to work I'll try replacing them with equally powerful ones, and see if that works.
I would email him for a price to repair yours first.
