KLH 50w Subwoofer 59.88
45 to 180 Hz frequency response
i dont think this is too good. i suggest u save up little bit more and get, sony SAW M40 , you should be much more satisfied.
however this might be ok for gaming maybe..
Well, $199 for the sony sub is much more than
<< a little bit more >>
than the KLH sub at $59. However, consider buying a 100-watt sub as opposed to 50-watt. I bought an 8-inch 100Watt KLH sub at Frys for $59 couple of months ago and that sub is great for the money...
<< however this might be ok for gaming maybe.. >>
I would think that Sony sub might be ok for gaming, but probably not the best for music. 12" sub from Sony sounds like a recipe for slow and boomy bass.
This sub kinda sucks...
My bro bought one for Home Theater / computer use, and it sucks for *both* applications.
Then again, I have a 440watt 12 inch sub, so I'm used to much stronger bass.
I'd have to NOT reccomend it.
-Drew
