Believe me I'm no expert, but basically connecting the L7 bridges ups the core voltage of the Duron to 1.85 volts.
So after connecting those bridges, go into the bios and reduce the multiplier (for me 5.5 is good because that is going to be multiplied by 133 soon and I have a Duron rated at 800 mhz, so I have a lot of room to play with.
Shut down, pull power plug (important), set jumper to 133.
Reboot, in bios readjust core voltage to 1.6 , and multiplier desired.
If you do not post you might try shutting down, clearing your cmos, set for safe defaults, optimal defaults, reduce multiplier and try again.
This seems to work for version 1.1
