hey folks,
I to am having bad experiences w/kk266. I cannot find any info in the manual about using the raid controller(disabled)for 1 ata100 hdd. I tried many setting in the bios(advance bios settings/second boot device)but periodically get this error in windows 98se..Windows encountered an error accessing the system registry. Windows will restart & repair the sys. reg. for you!!!
It has something to do with the ata 100 ibm hdd & raid controller because I don't get the above error when I put the hdd on ide0. The reason why I want to use the raid controller is because I have a plexwriter 16/10/40 & a 52x cdrom that I want to run on their own controllers. I was able to do it on my abit kt7a with no probs... Also I should have this option if I want!!! Also my win explorer periodically takes 6 to 10 sec. to open(even a couple times it took longer,can run another proggie then bam, it shows up)& when I try to explore my cd-rw/cd-rom contents it also takes 6 sec. not so on the kt7a with same components but for the plexwriter. Is it the brd or something else? Am I just being picky? I dont think so!(I LOVE SPEED!!!)pls help me to find these problems.
Thanks in advance, Spanky.
