KK-266R Question, Reference FSB
DollarBill
344
They say the only stupid question, is the one that's not asked. The IWill K-266R is listed as 266FSB. My question is that will it except the 200 FSB chip? I will assume that the board will support up to 266 (right)
AnMig
1,760
this ones easy , yes the kk266 will accept cpu 100 or 133 fsb/ you merely have to set the jumper for 100 or 133. Should be in the manual. Even if you get a 100fsb cpu might be worth a try to set it at 133 anyway.
good luck
DollarBill
344
I had my order filled out at NewEgg and was about to send it when all of a sudden the question hit me. I already have a 1gig thunderbird AXIA 200 FSB. The 266FSB question then puzzled me. Thanks
Please disregard this thread, all my questions have been answered.
