Anyone have a rag holder type thing fold out from under sink??
It would be in the position of the false drawer plate just below the sink. Ive seen kits that allow you to angle the plate out when you pull on it, and then have your dishrags and stuff in a little pocket.
I'm going to take it a step further and add a can shuet to a can box in the basement. I measured it out, and it looks like it will work, but I just can't think of what the kit is called to convert the drawer plate.
Any ideas??
EDIT: Figured it out "sink front tray" is what it is called. Thanks everyone for the replies
Any ideas??
