Kingwin LZ-1000 Power Supply
alleycop
Anyone ever used any Kingwin stuff? I'm looking to get this one.
Kingwin LZ-1000. It's a LAZER series modular PSU. The reviews for most part say it is good and it's $150 bucks.
I'm using:
I7-3820
2 x GeForce GTX 560 card
1 x 120GB SSD
1 x 1TB WD HD
Kingwin's Lazer units are decent, especially the higher end ones with Gold and Platinum efficiency. That unit is only Bronze with 3 year warranty, so $150 is way too steep a price.
For 2x GTX 560 you don't need more than a 650-750W PSU with four PCIe connectors. 1000W is ridiculously overkill. If you're buying from newegg, there's a sweet deal on a Seasonic X-650, only $90. It's Gold rated, fully modular, semi-fanless and comes with seven year warranty.
