Kill-A-Watt power meter accuracy
Modelworks
16,240
7
I had a friend over today that wanted to show me his new purchase, a fluke 1735 , so I thought I would do a quick comparison with the killawatt.
The killawatt isn't a bad meter, especially for the price.
Its does have its flaws though.
Comparing it with a fluke 1735 I found a few differences.
The killawatt is terrible at inductive loads, so don't use it for measuring those.
Inductive loads would be things typically with motors, compressors.
So not good for measuring a refirgertator or washing machine.
It measures them , but its results are not .2% accurate.
Refrigerator with compressor running 921 watts, fluke 841.8 watts
Its not accurate at measurements of small wattages.
Things like the power usage of a dvd player in standby mode are not accurate.
Killawatt said dvd player was using about 5 watts, fluke 2.64 watts.
The sampling rate is very low compared to meters like the fluke, so it can miss quick spikes or surges in usage . When I used it to measure the power usage of a 51" hdtv at turn on, it constantly gave different readings. Range from 410 watts to 504 watts. Fluke 448 to 453 watts.
PC, using a 750watt Ultra lsp model.
Core2, running at 3.3ghz, 7900gtx , pc running gelato (nvidia software that uses the gpu as a fpu, while also using the host cpu), maxes both.
Killawatt 316watts, fluke 329watts.
All that said its still a good device to use.
Its not as good as some of the professional tools like the fluke 1735, but then the fluke meter is over $2000 while the killawatt is less than 20.00
Be aware this is a very old thread.
admin allisolm
MrOblivious
92
Yes these among other issues (greater than 100% efficiency) show up when using a Kill-A-Watt with a PC power supply. Unfortunately, most people believe it is accurate all the time :(
Zap
22,377
I recall the issue as being 100% efficiency, not greater than, and it only happens sometimes with APFC units.
MrOblivious
92
The very first example I showed about the issue was greater than 100% efficiency.
http://img.photobucket.com/alb...e_c_t_r_e/100_1218.jpg
OK and seriously for the life of me is there a way to put pictures in and have the show through on the board?
As for it being only some PSU's....there are a lot more than people think that did it originally with more and more newer units giving it problems. As for why it is doing it....well that is a longer story it seems.
Mwing
294
i just google kill-a-wat accuracy and this thread showed up
im waiting for my kill-a-watt shipped, just a question here
say my psu has a efficiency of 70%, if kill-a-watt shows 400w, does my computer consume 280w? or do i take the reading on the kill-a-watt and divide it by 70%?
thanks.
imported_Scoop
773
thanks.
It measures off the wall. Your system consumes 400W but the components don't draw more than 70% off the PSU.
Zap
22,377
Basically.
Aluvus
2,913
No, it's been disabled.
Your first number is correct. You would multiply the reading on the Kill-a-Watt by 70%. This is only an estimate, because your PSU's actual efficiency will vary with different loads, but it should be good enough for most purposes.
SparkyJJO
13,357
7
Well then I guess I won't bother getting one. I thought it would be handy, especially so I know how much my crunching farm is using so that I won't pop any breakers if I decide to expand, but if it goofs up with APFC, no point. Not all my systems have APFC, but my main rig does.
ch33zw1z
39,039
19,731
Just want to point out the vast price difference between a Kill-A-Watt, and the referred Fluke 1735. Looks like the Fluke goes for about $2k, Kill-A-Watt starts about $20...Of course there's going to be a difference..
Zap
22,377
It IS handy. Don't let the inaccuracies stop you from buying this. Heck, even the most expensive $2k gear sometimes have issues with certain PSUs. IMO as long as you know not to take the readout as gospel, the Kill-A-Watt (or Seasonic Power Angel - same product in different plastic) is handy to give a rough comparison between systems for power draw.
Modelworks
16,240
7
As I said in the first post.
erwin1978
1,654
10
I have the P4460. I have a LED desklamp with clock. If clock is on by itself the meter won't read it. If I turn the light on as well then it will read both. Not accurate at low current draw.
