Kill A Watt device - max draw 15A - Can this not work with a PC?
Syndicate
1,798
Hey guys,
Found this:
http://www.******/kilwateldet1.html#description
Good deal with a free ship coupon but I noticed the maximum amperage draw is listed as 15A.
Our PSU's of today draw more then that on a single +12v rail. I wanted to use this to test some configurations and find a good balance of power draw from a few PC configurations.
I don't know if PSU amperage draw equates to what's pulled from the socket so I wanted to know if a typical modern PC is simply too much for this device. Anyone offer some insight? Thanks.
Aluvus
2,913
15 A @ 110 V is 1.65 kVA. You would need to be drawing well over 100 A at 12 Vdc (even accounting for power supply efficiency) before you had a problem.
Many homes use 15 A breakers (which may feed power to an entire room) without incident.
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
For reference, my machine in my rig pulls 2.82 amps out of the wall socket when I maxed out the machine all I could.
PurdueRy
13,837
4
Originally posted by: Syndicate
Hey guys,
Found this:
There is a conversion that occurs in the power supply where voltage is lowered and current is increased.
Syndicate
1,798
Fantastic guys, appreciate the response! Got a formula to figure out the real capabilities.
My AC/DC conversions and what not are obviously a little out of date :)
EDIT: Yowch, Anandtech removed the link :)
Fike
388
I have used the kill-a-watt on my PC. It draws about 200-245 watts. At 110VAC that would be just over 2 amps or the equivalent of 2 or so 100 watt light bulbs.
wattage=current X voltage where current is measured in amps and voltage is measured in volts. So, as others have pointed out, that amperage is at a much lower voltage, so the overall power (wattage) is still relatively low. You can of course make all kinds of correlary formulas froma nice simple formula like this: current=wattage/voltage.
Zap
22,377
7
W = V * A
Watt = Volt (times) Amperes
Matthias99
8,808
Originally posted by: Howard
You don't run it from your +12V supply, do you?
No. It plugs in between the wall socket and the PSU. In fact, it provides zero information about how much current is coming out of the PSU's rails. The only way to get that kind of information would be to wire an ammeter into the outputs of the PSU (which some review sites have done, but it's not for the faint of heart), or use an induction current meter (which doesn't require splicing wires, but is somewhat less accurate).
As pointed out multiple times, it can measure up to 15A of 120V AC draw.
15A * 120V = 1800W.
Most household outlets are breakered or fused at 15A, so you are unlikely to be able to exceed this anyway.
Bob Anderson
188
Hey guys,
Found this:
You misunderstand the difference between the maximum amperage available on a PSU 12volt rail, and the amperage available at the wall AC, which is typically 15 amps at 120 volts in North America. This is FAR more than any home computer could use.
Get the Kill-a- Watt, though. It is a fun device.
-Bob
Howard
47,982
11
15A * 120V = 1800W.
That was a rhetorical question. :D
Ferzerp
6,438
107
A little more than "somewhat less accurate" on a DC current ;)
Jiggz
4,329
See what happens when you open a can of electrons? Soup bowlful of electricians will show up!
zagood
4,102
"Waiter, what's this electrician doing in my soup?"
"I believe that's the backstroke, ma'am."
hahahahaaaaa...oh.
Any B&M's that carry the kill-0-watt?
-z
Rubycon
Madame President
Aug 10, 2005
17,768
485
Currently it is. There are 1.5 kW power supplies on the horizon. :Q
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
And people thought it was bad when they had to upgrade for Vista. Wait til they find out they have to upgrade the wiring in their house for that.
mithrandir2001
6,545
I'm glad I am not a bleeding-edge hardware enthusiast: 1.5kW power supplies simply seem objectionable to me. With the energy challenges the world faces the prospect of having PCs that can draw over a kilowatt of power just to play games suggests our priorities are out-of-whack.
The current power supply situation reminds me of the late stages of the NetBurst product cycle. Eventually we are going to hit some proverbial wall and realize we will need to do more with less.
Blain
CPU's are consuming less while GPU's are getting more power hungry all the time.
