Bateluer
I like my Revo 3610, but its a little under powered for my original intentions, video playback while connected to a 1080p LCD TV. So I started kicking around the idea of building a mini-ITX machine that I can connect to my TV that can easily be hidden or otherwise be unobtrusive. The TV is wall mounted, so the case cannot be mounted to the back of the TV.
I was looking at the case below.
http://www.newegg.com/Product/Produc...82E16811154084
Its got a 250W PSU and enough power connections. I intend to put in only a single hard drive and a BD-ROM drive, which I gather from the Newegg reviews makes the case a bit cramped. Also, gathered from the reviews, that the interior can get a little warm, but is easily remedied with the addition of a PCI slot cooler, which I have sitting in a box in the closet. Looking at the design of the case, I think this would remove the possibility of using a PCI 802.11n card, though a USB wireless adapter would likely work just as well for wifi.
For the motherboard, I was looking at this Intel LGA775 model.
http://www.newegg.com/Product/Produc...82E16813121381
Its a G41/ICH7 type, with support for the whole range of C2x CPUs. Its X4500 IGP is obviously weak, but I believe they do have some video acceleration capabilities, if I recall correctly. Fortunately, unlike the Atom based Revo, a faster CPU should be easily able to make up for that shortcoming.
For CPU, the Celeron E3300.
http://www.newegg.com/Product/Produc...82E16819116264
I did look at the LGA1156 models, however, the Core i3 CPUs are double the price of the Celeron E3x00 line. I am not certain if the Intel HD video is worth paying ~114 vs the ~50 of the E3300.
I have several hard drives here I can use, so no need to worry about those, and I can easily load the machine up with 4GB of DDR2 800 RAM, so no worries there. I think that covers all the bases for hardware.
Now, for capabilities, is the E3300 powerful enough to decode 1080P level content on its own, without assistance from the IGP? 1080P content may include Flash, BluRay, x264, etc. I know the Atom 330 in the Revo is completely not able to do any of this on its own.
Not sure if it would be worth it to spend the extra money for the i3 motherboard and CPU or not. Going i3 would double the cost of the motherboard, CPU, and require me to add the price of some DDR3 RAM to the mix, so it'd be nearly double the cost. But the LGA1156 motherboard seem to boast more features and ports than the LGA775 ones do.
This would likely run Windows 7, although WHS or Mint could also be used.
Any insights or feedback?
