Not sure about the Kia engine, but almost every DI engine still has this issue. The severity depends on a lot of factors.
Having said that, there are options available to alleviate some of the carbon buildup.
a) Walnut blasting - offered for many cars, typically not by the dealership though. I know for my WRX, it's not a complicated job (i.e. I can do it myself if I wanted to) and kit's are available online.
b) Additives in the intake tract - Sometimes called a "Top Engine Cleaner", sold by CRC and a few other makers (including a Subaru branded version). Basically injects a solvent into the intake tract of a running engine so it gets sucked in through the intake charge and "cleans" the top of the valves. Not as good/thorough as walnut blasting, but decent preventative maintenance that could delay the effects of the carbon buildup.
c) Catch Can - to prevent what's driving the carbon buildup on top of valves (basically the oil vapors routed via the PCV into the intake tract), the oil vapors are routed into a catch can. Lots of kits available to do this.
