- Jun 30, 2012
- 7,306
- 5
- 0
Other warning: Somewhat technical long-winded rant ahead. And yes, cursing.
I used to not have anything against Kia/Hyundai vehicles, but I'm trying to troubleshoot something right now that is changing my mind...
'08 Kia Rondo. Cranks, but won't start. Some idiot tried to put a fuel pump in it to fix it...yeah, no go. Maybe you should check the relay first, chief. I know it takes fifteen seconds and all, but making sure it turns on is a good first step before replacing a fuel pump...
But it's not just the fuel pump relay. Not a single thing in the engine fusebox turns on, other than the starter relay. All fuses are good. No communication with ECM through DLC.
So I find out about their technical resources, which are online and available to anyone who wants to look at them. No dealer or technician ID required. Gee, I guess they don't have much confidence in their dealer techs. Explains why whenever someone incompetent at a shop actually gets fired, I always hear later about how he's now working for the Kia dealer...
Anyway, so I start poring over any relevant information I can find.
And HOLY SHIT does Kia suck at technical info. They seem to be going the way of most manufacturers (but worse); put most of your work into trouble-trees for simplistic issues so you can hire more inept people who don't have common sense. Forget good reference information.
Their wiring diagrams are not complete. Rather than, say, show diagrams of entire wiring harnesses or entire systems, you just get a bunch of pages of little snippets of fucking play-skool diagrams relating to the area you selected. Best I can say is at least they do have pinouts/signal specs.
But I still can't find the info I really want...just one question: what turns the ECM/PCM on? I see which wires are power and ground, but none are ignition-switched. I see that there is an engine control relay...which is turned on by...the ECM. Okay...what tells it to turn that on again? And why can't I have an ignition switch diagram? Best I can tell, the ignition switch just activates the BCM...so I guess the BCM turns the ECM on...but there's no identified wire for that...is it through CAN bus? Hmmm...
I have to go back to just googling. I see all kinds of no-start problems, but nothing that mentions the complete deadness that I am seeing...I see plenty of bad fuel pumps, fuel pump/other relays, crank sensors...they get ignored because none of them would cause the ECM to not function...then I run across this lovely page, in which expert Kia techs instruct a guy with the same problem to do things like...check relays...check sensors...even check compression (wtf?). But the important part is at the end...
...the guy actually did fix it with a crank sensor. So putting that together with the previous incomprehensible crap, I think I've figured it out. Ignition switch triggers the BCM...BCM triggers the starter...cranking signal from the CKP triggers the basic functionality of the ECM? What the FUCK?
I haven't yet confirmed that this is the same issue by putting the part on it, because it seems too absurd. But I think this IS the crankshaft sensor failure I keep reading about...it's just that apparently no one bothered to check the proper things...just complaints of 'I have no spark' or 'I have no fuel' or whatever the first thing they found was...and someone said 'try a crank sensor.'
How the fuck can these cars even be sold in this country? Doesn't this violate OBD2 compatibility? An ECM input goes out and the programming dictates that the computer will no longer even allow diagnostic communication through generic OBD2? Has anyone worked on these shitheaps and seen this problem?
Cliffs: Suck my fucking dick, Kia. Go back to Korea and let us make our own shitty cars. At least I can fix them when they break without having to just randomly check every part on the car because you're SIXTEEN FUCKING YEARS behind the computer diagnostic curve.
Might want to ease up on the profanity ranting...
AT Moderator
Bartman39
edit: okay, I warned that there was cursing in the post in the thread title that had no cursing. I apologize for not following a rule that doesn't appear to exist. Please notify me of the curse word limit so I will be more careful in future posts. And no, that's not me being a smart-ass, that's a legitimate request. Don't cite me for profanity if you can't concretely define what constitutes 'too profane.'
While the occasional F... word is common place in a social forum a rant such as this has been discussed by the staff and it is a moderators discretion when it becomes excessive as in this case... In OT this is not a problem to a certain extent but even there lines can be drawn but remember there are many that come to the garage to learn and not read a rant that makes your point meaningless... The warning will stand and in the future take it to moderator discussions and do not post a reply in the post you have been warned about, this is considered a moderator callout and will result in more infractions...
AT Moderator
Bartman39
Thread closed pending questions answered by OP...
AT Moderator
Bartman39
AT Moderator
Bartman39
AT Moderator
Bartman39
AT Moderator
Bartman39
