KHS Flite 2000 bike frame.
jsbush
3,871
I was looking into the Flite 2000 frame for the bike I'm putting together, would anyone recommend it? and for what resons? Does anyone have a better frame? How much does this frame go for approximate?
KHS Flite 2000
JACKHAMMER
I am partial to voodoo Frames, but I am not quite sure if they make a road frame or not. I would suggest looking into it.
Mursilis
7,756
11
The 'best' frame is subjective - what do you want? The lightest? The cheapest? The stiffest? The strongest? The best ride 'feel'? More info needed.
Capn
2,716
try mtbr.com
other than that, composites scare me. They're light and all, but if you don't really need the weight improvement. Maybe I just have an irrational composite phobia. :)
jsbush
3,871
A light frame is all I need. I won't be doing serious mountain biking, just the little tiny trail once and a while and a lot of hard pack flat trail.
Mursilis
7,756
11
Check www.supergo.com - they have some awesome deals. I've got a Schwinn Homegrown Factory, and it's a great ride, but there's also some other great stuff there. As capn mentioned, www.mtbr.com is a great site for reviews.
I wouldn't be too afraid of composite (usually carbon) bikes. I've owned two, beat the heck out of them, and they're still running today.
jsbush
3,871
KHS
It's a good price and seems like a good bike with the Shimano Deore (the gears I wanted to get) and a Rock Shock fork, think I should get it? Should I buy online though. I dought I can find cheaper here, but it will cost a fortune in shipping. I'm in canada.
benjamit
775
don't get khs they are pretty low end
trek, cannondale, gt even raleigh are better than khs
benjamit
775
unlike computers many other tech things cost more to build from parts than buying it
this includes cars, motorcycle and bikes
if cost is not a factor than get the best dual suspension, carbon fiber, XTR (it's been a few years since i rode so XTR's may not be on the top), clipless, etc
a good frame is going to cost 1-3k, less expensive is the drive train package 1k, then your wheels .5-1k, last is the rest
Feb 10, 2000
30,029
67
Actually IMO KHS is not bad. FYI, your first link leads to a completely different, Alu/CF road bike. The bike you are considering seems like a perfectly solid MTB suitable as an entry-level trail bike or decent all-arounder. Given the specs I would expect it to cost around $600, so the Supergo price is (as usual) very good. Be VERY careful with sizing if you are going to buy a bike online, though. It looks like they only have 19" and 21" bikes left, so this is probably not a good bet if you are below roughly 5'10".
jsbush
3,871
I'm ~5' 8" 5' 9" so I'm guessing the 21" is good? Is this bike good for long trips and high speeds? I'm not talking about speeds like on a racing bike but 25-35KM/h? I use my bike to go to work and get around town, will this bike bring me there easier then my CCM aluminum bike? The shipping weight is only 30lbs so my guess is that bike is light, my current ccm bike is about 35lbs.
Feb 10, 2000
30,029
67
<< I'm ~5' 8&quot; 5' 9&quot; so I'm guessing the 21&quot; is good? Is this bike good for long trips and high speeds? I'm not talking about speeds like on a racing bike but 25-35KM/h? I use my bike to go to work and get around town, will this bike bring me there easier then my CCM aluminum bike? The shipping weight is only 30lbs so my guess is that bike is light, my current ccm bike is about 35lbs. >>
No, no, no! A 21 is about right for me, at 6'4&quot;. No offense but if you are this far off-base on sizing this will NOT be a hot deal - size is the most critical issue in finding a bike you will enjoy. Even the 19&quot; is probably too big, unless you NEVER intend to take it off-road.
jsbush
3,871
My best bet would be to go to a local sports store and try out there 19&quot; bikes and see.
Mursilis
7,756
11
I'm 5'9&quot; and I've always ridden mtbs in the 18-19&quot; range, even off-road quite a bit. It depends on how the frame is measured. Anyway, if you're a bike newbie, you should probably buy from a local shop. Most usually throw in a year or two of free maintainence, so that's something to consider.
jsbush
3,871
This really sucks! It will cost 160$ to ship to canada, plus the exchange rate, it will cost me about 950$. :(:(:(
I will buy locally!
yakko
25,455
<< if cost is not a factor than get the best dual suspension, carbon fiber >>
eeeeeeewwwwwwww!!!!!!!!! Carbon fiber and suspension are the two worst things about mountain bikes.
No, no, no! A 21 is about right for me, at 6'4&quot;. No offense but if you are this far off-base on sizing this will NOT be a hot deal - size is the most critical issue in finding a bike you will enjoy. Even the 19&quot; is probably too big, unless you NEVER intend to take it off-road. >>
I am 5'8&quot; and I feel most comfortable on frames that are 14 to 16 inches.
jsbush
3,871
I have come down to the following bikes.
KHS Alite 1000 or 2000
K2 ZED 4.0
Trek 6500
GT Agressor 1.0
Specialized Hardrock A1 comp FS
Schwinn 2000 Mesa GSX
Giant Iguana SE
Devince Cameleon, Taos, or Saguaro
They are all hardtail bikes. Just woundering what you guys think of them.
