will KFA2 GeForce GTX 550 Ti White do me for gaming i am using 1900x1080 res. will this be able to play the latest games on the highest setting well?
all of your current specs need to be listed too.
and you have no video card now? and what about psu?i have 4 gig ram, amd athlon x2 260, win7 enterprise x64
yeah anything will be an upgrade over that card. what 650 watt psu do you have though?o yeh lol i have 650 watt psu and right now i have hd 5450
well you dont put a higher end gpu in a system with a cheap psu. can you at list list the model so I can see if it is actually decent enough?baisicly i jus spent £350 on more stuff for my pc like 1tb hdd, hd monitor,another 2 gig ram, KFA2 GeForce GTX 550 Ti White and my psu is only a cheap one to keep it running ill end up buying something better in the next few months.
where was I comparing a 6850 to a gtx550? my post had nothing to do with any specific card at all and I was only talking about in general terms.You do if the GPU uses less power than his current one.
The HD6850 stock uses less than a stock 550Ti, and 550Ti overclocked cards are around the power use of a 1GB GTX460.
Despite being on the lower end, they aren't low power cards. The KFA2 even has dual 6-pin connectors.
at first i was gonna get the hd6850 but then i saw the kfa2 it looks mint so i got that one instead.
All power ratings indicate peak power.
So, you already bought it?
Expert tip: Ask first. Buy last.
You still didn't list the brand or model, but this last line doesn't look promising.
