Keyboard USB ports with powered hub?
ZoSo
I'd like to use my USB ports on my keyboard for flash drives, when I try I get a message saying "USB Hub Power Exceeded".
I was wondering if I attached the keyboard itself to a powered hub would I then be able to connect flash drives to it?
TIA
bruceb
8,874
111
No. But if you plug a powered USB Hub into the USB port on the keyboard, then the ports on the Hub will have plenty of power.
corkyg
Elite Member | Peripherals
27,370
239
If you have a powered hub, you can try it either way and see what happens. It can't hurt anything. USB ports are set to supply about 5vdc. Bruceb's solution definitely will work.
Peter
9,640
If you've got the keyboard directly on the computer now, then no, plugging it into a self-powered hub won't change how much stuff you can plug into the keyboard. That's because the computer itself counts as a "powered" USB hub as well (quite obviously).
bruceb is technically correct ... however I'd plug the powered hub into the computer, not into the keyboard. That's because I like to move the keyboard around on my desk, and the more wires attach to it, the more immobile will it become.
