Hi all.
I just installed a new motherboard with RAM and CPU into my home system.
In:
Athlon XP 1700+
256mb DDR
Gigabyte GA-7VXH (the KT266A one)
Out:
P3-667
256
Gigabyte GA-6VX7
Problem:
I just swapped the boards over, no re-install of the OS or anything. I have swapped mainboards under Win 2000 without a re-install before and the OS has just sorted it out.
Everything boots up fine, I can get into the BIOS and manipulate settings, but for some reason the keyboard does not respond when I have booted into Windows 2000. At first I thought it would be a faulty PS-2 port or keyboard itself, yet threw that idea out of the window as the keyboard works in the BIOS!
Any ideas? I'm stuck as of course I cannot input my password to enter the OS, and therefore I cant access device manager... 🙁
HELP!
Thanks for any suggestions.
In:
Athlon XP 1700+
256mb DDR
Out:
P3-667
256
Gigabyte GA-6VX7
Problem:
HELP!
