- Jul 26, 2004
- 192
- 0
- 0
My old keyboard and mouse are starting to act up a bit, so I plan to replace them. The question is, what setup works best for me?
I want to be able to use the keyboard and mouse both from my computer desk and from a couple other spots around 6 and 12 feet away. The keyboard must be ergonomic and I'd like a mouse with at least 5 buttons, including an easy to game-with scroll wheel.
The problem is that ergonomic wireless keyboard reviews tend to suggest that the wireless ranges are extremely, and I mean extremely, limited. It can also be hard to find a good mouse that meets my specifications.
That said, should I get wired versions of both of these components and pick up extension cables that will reach the distance I want, or can someone recommend a solid wireless choice? Is it wise to consider some sort of setup whereby I can swap between wired at the desk and a wireless setup farther away with a switch? The distance usage isn't nearly as exacting, so if this was a good option I could get a cheaper, non-ergonomic wireless setup to match whatever wired choices I may choose.
Thanks for your time.
