Keyboard and Mouse are Freezing!
TheRyuu
5,479
14
I have a serious problem, whenever I play CS:S (not sure if thats the only game it happens in) periodically the mouse an keyboard just wont respond. I start hitting buttons and then the case start to go beep beep beep whenever I hit a key. Meanwhile in CS:S, people are shooting my ass off and I start to loose :( .
Why are they freezing? I have Logitech G5 mouse and G15 keyboard. If you need more info I'll gladly provide ;) .
Help me! :p
us3rnotfound
5,334
Sounds like your system is running low on resources, which is why it is beeping when you tamper during the slowdowns.
EDIT: Actually, your computer is quite fast. Did you install the latest logitech drivers and mess with the wireless channels?
fire400
5,204
21
I've noticed many users on this forum complaining about Logitech. I for one thing have had problems with Logitech as well in the past. I will never buy from them.
Anyway, you probably didin't need to hear that. Reset your BIOS and check your batteries if they are wireless and if they are check if there is any interference? Are they USB? Check if the USB ports are having IRQ conflicts with other devices?
us3rnotfound
5,334
Things change
TheRyuu
5,479
14
Actually, this is not the "Opty Rig" in my sig. Its an older XP 2800+ if that helps. Hopefully UPS can deliver my mobo today and I can get the thing running so "no more starved resources".
But anyway, I'm running latest drivers, latest firmware on mouse, latest everything. I skipped the install CD and downloaded all the dirvers straight from Logitech's site. It doesn't seem to freeze alot, only when I don't want it to in CS. And it doesn't seem to freeze any time else. Maby its because the mouse shoots data over it's USB line so fast.
