Kenwood VR6050 receiver(refurb) for $99 @eCost
ConnCarl
276
This is a great box for the money, if you don't need true Dolby Digital 6.1. Built-in DTS Decoding, support for two sets of main stereo speakers, 3 digital inputs, 3 S-Video inputs, and gobs of power, rated the way it used to be, in the good old days; from 20 - 20,000 hz at less than 0.09% THD.
And free shipping! Woohoo! I think I'll fleabay my unopened Best Buy KLH receiver and replace it with this one. How can you go wrong?
CyberTron
626
after looking up some reviews, I snagged one, I dont think you can go wrong here, $99 is a steal for any name brand receiver like that one. now just to pickout some speakers, i remember a thread back way when for some 5.1 system floor standing and was totally kick ass. but id ont rembmer and im sure its gone by now. name of the speakers started with an F
fonzinator
953
Fluance is what you're thinking of.
BigSmooth
10,484
12
just found that thanks.[/quote]
You'll have a GREAT system on that type of shoestring budget. Believe me, this Kenwood will be FAR better than any Sherwood, KLH, or pretty much any receiver you can get for $99. I have also heard nothing but good things about Fluance. If I needed a second system, I'd buy the exact same stuff! Good luck. :)
edplayer
2,186
what kind of warranty does it come with?
edit: just called. 90 days. 1 year additional for $20.
mzkhadir
9,509
I bought one a while back, it is a great receiver, I bought the VR-6060 one from Best buy at 260 I think on clearance.
docprego
15
Has anyone bought one of these refurbs from Ecost? Though their page says it does, is it certain that the multibrand joystick remote is included?
Also the specs on Ecost's page for this receiver say the following: "Kenwood's Circle Surround II, which let you transform Dolby Surround and stereo sources into realistic 5.1-channel and 6.1-channel sound, respectively"
Then it mentions this: "Dolby Digital EX, DTS, and Dolby Pro Logic II"
What is the truth, isn't this a 5.1 receiver?
tigerbait
5,155
it has amplification for only 5 channels, but the processor can handle 6.1, so you need to take the preamp output to another amplifier in order to utilize the back surround.
BigSmooth
10,484
12
Yes, it's 5.1 Circle Surround is a propietary technology that can take a 2-channel source such as TV or a music CD and play it back in a 5.1 format so you utilize all your speakers. It's actually similar to Pro Logic II but I find it superior in some applications.
edplayer
2,186
yes. It is a 5.1 receiver (5 channels of amplification)
manual: ftp://docs.kenwoodusa.com/manuals/OM-VR-6050-2002-KUSA.pdf
mzkhadir
9,509
This is what Kenwood says
An A/V receiver is the centerpiece to a great home theater system, and the VR-6050 delivers. It processes surround-sound information in Dolby® Digital EX, DTS, and Dolby® Pro Logic II formats for a powerful, theater-like experience in your home. SRS Circle Surround II lets you create 5.1-channel sound from 2-channel sources such as CDs, video tapes, and FM radio. The VR-6050 delivers a powerful 100 Watts into each of five channels in Surround mode and 100 Watts per channel in Stereo. Its K-STAT Discrete Audio Amplifier, a Kenwood exclusive, helps to ensure the highest possible signal purity, and a six-channel analog audio input means it's ready for DVD Audio and other multi-channel formats. For convenience, the VR-6050 provides a full complement of other AV inputs/outputs including S-Video and subwoofer/Surround Back pre-outs. A universal pre-programmed remote with joystick control is included.
Here is the link to the manual too. Manual: VR-6050
ConnCarl
276
Well, I put my money where my mouth is and bought one. My credit card company should double the warranty, for a total of six months.
My trusty old Kenwood KR-V6050 Dolby Pro-Logic receiver is still going strong after about 10 years, and if I hadn't discovered DTS digital sound, I'd probably still be perfectly happy with it. We'll see how the new one holds up.
RobsTV
2,520
Thanks!
Asked my audio tech friend about this (I only do TV's), and he said it's a great unit for this price.
Rarely has problems.
He uses a Kenwood at home as well, so it must be decent, as we have access to just about any
units near free cost (in need of repair).
halik
25,696
ordered one...god damn you!
o well i can sell the old one for decent amout, so its not too bad :)
CyberTron
626
Yea, im waiting for mine now, kinda drooling over these Fluance speakers, just dont have the cash right now, but my question is this.... I see power ratings for front, back, and center, what about sub? I see Fluance has powered subs now, and was wondering if i should get the 150w or 200w, course thats thinking a little ahead, but still. any takers?
Amploud
88
I have this exact reciever. I bought it over a year ago at Best Buy for $225ish on sale. It sounded better than anything in the price range. It is my stereo and home theater system. Personally, I love this reciever. Yes, there are better out there, but not in that price range. For $99, you would be crazy not to buy it if you don't have a reciever!
Lots of features, (that I don't know how to use!) lots of hookups on the back, great sound quality, lots of power, and other things make this a great value. I have mine driving 5 speakers and all of them get very loud with no detectible distorsion.
ConnCarl
276
Cybertron, you answered your own question, sort of.
The Kenwood has only a preamp subwoofer output. So if you would like to use a subwoofer, you need a powered one, such as either of the Fluance units you mentioned.
Mallaur
Thanks a lot for the heads up, picked one up also. More then time to retire my 12 year old Sony
